Kaz
Hello, all. Phx Comicon is coming up, and I've been slowly working on a Ravage costume for it.
Yes, this Ravage -
So far I've made a dtd to build it on, have the front leg stilts made [ this is going to be on all fours, or else it'd be a pretty crappy Ravage hm? ], and the base for the tail is done.
Plan to work on the head tonight - I got a red led light for his eye, and hopefully the armor for the thigh area. If not that, then possibly the tail.
Will have something worth while to take a photo of soon.
Bits on it..
Most of the material used will be foam - since its basically going to be like a giant armored suit, in a way..
The tail is plastic with wire through it, and a pool noodle over that, nice and light. - The wire through it will be then attached to a belt to hold it on. The spikes are cut from a plastic bin and are being riveted together, then will be attached over the noodle, then painted.
His end gun is a pvc pipe, with wood bits carved out for those spikes on the end.
As with his tail gun, the guns on his back are going pvc as well. Plan to have this attached to a plexiglass base which'll be attached to the belt the tail is going to be on. Since he doesn't always have his guns out though, if time doesn't allow, I won't have them for the outfit for the con. Can add them later.
Yes, this Ravage -
Bits on it..
