Gunpowder
This is a current commission build. Its the resin 38 inch long Randy Cooper Stardestroyer. Ive been asked to light this too which is a real challenge. The main hull is made from 8 beautifully cast resin pieces. Ive bult the lower hull so far and alot of cutting and drilling have been required to allow for the fibre optics to be fitted. There will be hundreds fited to this , but im sure it will be worth the effort.
This is one of the underside building parts with the holes drilled
Due to the hull and the buildings both being solid i had to cut through the hull to get to the other part.
More to come later...
