Predator Mask Dome Help
I kinda got the jist of what you ment. I used approximation measurements until i found the center of the circle. After drawing the lines needed i was able to come up with the following result.
Improved Dark bio mask. Was really annoying to make. Still gotta add pieces.
The first image is an edit to show how close i think i got
Short of using proper dreads (which really make or break a build) your only other options are to either make some from thin foam mat, or (shudder) use backer rod.  The biggest mistake people make is they use 3/4" backer rod, which is way too skinny.  If you have to go the backer rod rout, do yourself a favor and order some 1" backer rod.  The difference is huge, and it's way more accurate (if that's possible) than the anorexic 3/4" everyone uses.  Search google,  you'll find tons of suppliers for the 1".  Better yet, save your money and but a proper set of dreads... you won't be sorry.
Brian
