Limited Run PKD Water Gun Upgrade Kit, grips and ammo boxes Blade Runner Fullcock Takagi Blaster
SeattleMaddog
Re: PKD Water Gun Upgrade Kit, grips and ammo boxes Blade Runner Fullcock Takagi Blas
Got my kits last week, very happy. Now I just need to find time to complete the build.
Eric Ardros
Received my two kits earlier this week. All the pieces look great, and the decals are a nice touch.
Will make a nice upgrade for my water pistols. Well worth the wait! Many thanks, sir :D
Reel Fakes
Any update on the wiring diagrams?
Solo
Sent you a PM earlier about my deluxe kit order that, according to the shipping notice I received, should have been here 2 weeks ago. Any update on status is appreciated.
Reel Fakes
How about that wiring diagram?:$
Soulinertia
I'll try to get the wiring diagram posted tonight. Still working on the full instructions doc.
Mechanized
Hey Soulinertia, don’t know if this has been asked before but does your ammo box fit the Tomenoskue bullets?
Soulinertia
Not sure if the Tomen rounds will fit the box, they look like they would fit, but I can't confirm for sure. If anyone who bought an ammo box has a tomenosuke, let us know.
At this point all kits have been shipped. I've been experimenting with some new grip variants:
Navy blue: https://www.instagram.com/p/Bf849ONjZLj/?taken-by=fatal5150
Smoke: https://www.instagram.com/p/Bf_esQJj-l4/?taken-by=fatal5150
This one changes color depending on the way the light hits it: https://www.instagram.com/p/Bf1MPpOj8Gl/?taken-by=fatal5150
Here are a few more pics:
henselmonster
Member
Can you order a deluxe kit without the grips? I already have a pair of those from a few months back.
jugnor
Any news about instructions & electrical diagram?
Kylo1
Re: PKD Water Gun Upgrade Kit Blade Runner Fullcock Takagi Type Blaster by ELFIN KNIG
Gotta say, I'm very happy with how these grips turned out. Beautiful cognac coloring and after vacuum casting almost no bubbles!
https://i.imgur.com/HEQskBU.jpg
https://i.imgur.com/VIcdqSF.jpg
https://i.imgur.com/xFPwKV2.jpg
https://i.imgur.com/So5v48y.jpg
https://i.imgur.com/xEbM8gu.jpg
showing some light casting through it
https://i.imgur.com/skH8O0J.jpg
Darker richer color compared to the stock plastic shells
https://i.imgur.com/7lsCNiC.jpg
Hi. Are these upgrade grips exactly the same size and fit as the originals that came with the water pistol. If so can I buy an amber set
Soulinertia
@jugnor
Here is the diagram to wire up the LEDs in parallel:
You really don't need a resistor for each LED, but for those that got the deluxe kit it is already built in. If you got the basic kit then you would just put a single resistor between the negative battery holder lead and the first LED.
Soulinertia
I have 2 different grip styles. One cast from the original grips (exact fit) and the newer Tomenosuke style grips that will fit a Tomen or on the watergun with a slight space above the base plate. I prefer the Tomen grips myself because they are a little thinner and the bolt holes are cast into the grip rather than having to drill them out, however they do require a little more mod work for a perfect fit. You can buy them through my website here: http://www.fatal5150.com/apps/webstore/
Just specify which type you want with your order. :cheers
Kylo1
Thats great thanks. I have just looked on your website and I can only see the solid version grips. I am after a set of the exact fit amber grips so please advise how to order via your website.
cheers
Soulinertia
OIC, Yeah I only offer solid resin grips.
Soulinertia
Oh ok cheers. Are they something you could perhaps produce though?
It would be quite difficult to achieve the desired results with a transparent slush cast and no bubbles. It would also be much more fragile. Also I don't think very many people want thin shells for grips. Most are going for the solid resin. Cutting away the existing plastic on the water gun with a dremel isn't too difficult and the overall appearance of the solid resin grips yields a much richer look.
