I use the 1:1 mix clear resin from Hobby Lobby / Michael's and have had no trouble with it. The kind in the tin that takes the drops of catalyst is just crap though.
I've checked out the Hobby Lobby today and they have the Alumlite kits on the shelf (in the same isle for miniature models (for dioramas and stuff). They had a mini casting kit with 8 oz. of solutions, Mold Putty, Super Foam 320, High Strength 3 and a Super Casting Kit (which is actually the most expensive item at $69, with everything else being less than $30). I don't understand the differences between them (except that the Super Foam 320 apparently is use to fill in cavities in items to re-enforce their structural integrity). So, what's the differences between the mini casting kit, Mold Putty and High Strength, short of the size, that Mold Putty doesn't require mixing in a cup, and pricing? And which works best?
I've mostly used stuff from micromark but they're expensive and this last batch i didn't have good luck with when it came to resin. I'm going to try smooth on next.
Mold Putty
High Strength
and other than realizing that Legos do in fact make the best mold boxes
I'll have to think about MDF when I next make some large models.
JOOC, why the fixation on finding a local reseller of the stuff? ALL of this stuff can be found online, and can be at your front door in a few days. Unless you're under some 24 hour time crunch, I recommend buying online.
FYI Hobby Lobby carries Alumilite resin and silicones and there is absolutely nothing wrong with them, they are every bit professional...
Try getting that at Michaels![]()
Another thing to note you will get that same level of Smooth On customer support at a local Reynolds Advanced Materials as they are one in the same...
As for the desire to go to the store itself to go shopping, you are of course free to do whatever you want for whatever reason you wantI was just worried that maybe you thought the good stuff could ONLY be found in brick and mortar stores, which is simply not the case.
As for credit card fraud, you are FAR more likely to be scammed from a brick and mortar store where they physically handle your card than an online place. Only a very small percentage of credit card fraud comes from online or phone sales. It's all just a perception thing. Like how people are afraid to fly, but are totaly comfortable driving on the freeways.
