Hi there.
I'm trying to completely disassemble my MGC Mauser at the moment, but I'm stuck.
Since you can pretty much take the MGC apart like the real thing, I used this manual:
http://www.surplusrifle.com/pistolc96broom...emble/index.asp
Now, I'm stuck at figure 18. I can turn the firing pin 90 degrees, but it just doesn't "pop" out, I can't take it out at all. The instructions say
I don't really get what they mean. Mine doesn't move out at all, even if I pull back the slide and try to push the pin out, it doesn't move a bit, I can only push it in...
Does anybody know how to do this?
Any help appreciated.
Xhiwar
18) The firing pin will “pop” out and then you can pull it the rest of the way out of the bolt.
NOTE: Some older models have a firing pin retainer that used a flat plate. The plate is dovetailed and can be released by pushing the firing pin inward to release the spring pressure on the plate and then slide the plate upward.[/b]
Xhiwar
