Anti
This super cool item has ceased to function and I'm at a loss for how to fix it. This is serious, because if I'm boarded by a Gorn, I currently have no way to sound Red Alert.
Here is the system in question (click for larger picture):
Standard Starfleet issue duotronic corridor communications unit. Runs off the secondary EPS taps but in a pinch will also run on a 9 volt battery.
Here's what it's supposed to do:
Two things. First, clicking the intercom button turns on the intercom light. That works. Second, clicking the red alert button turns on the red alert light and a klaxon/siren that sounds through the speaker. The light flashes on and off as the siren sounds.
Here's the problem: When I hit the red button, I get no light and a garbled, brief (1 second) squawk. This is what happens the first time I try it. Subsequent attempts get no reaction unless I unplug the battery. Reattaching the battery gets you one more garbled squawk.
I don't recall if (when fully functional) the light and siren sequence continued until you hit the button again, or if it went off by itself. I think when it worked, you could hear a clicking sound as the light went on and off.
The only parts I recognize are the relays, which are 1 inch cubes that remind me of the things that made the turn signals blink in my '74 Ford Grand Torino Elite (oh yea, I was stylin' back in the day).
Anyway, my best guess it that I have a power drain in the tertiary EPS coupling. Or maybe the entire assembly has phase-shifted (which would explain why my hand passes through it . . . after a lot of bourbon). Or it could be the flux capacitor. Or a Cylon logic bomb.
Any help would be appreciated.
