CSMacLaren
Eek, you're using THAT article? How embarassing! *BLUSH*
Dome is looking good. I tried something similar on mine, but was never really happy with the way it came out. Good luck on the rest of the helmet.
Lots of sanding, in your future, I see!![]()
Great job, looking miles better than the cheap lopsided mess it was.
Yeah, I'm still impressed too
The more I'm working on my Rubies, the more I understand the problems of that helmet.
The long nose, the sunken cheek, the mouthwalls etc.
I also was long time the meaning, the nose insert should be left in place and filed in.
But comparing it to my SPFX, I saw that extending the roundet part on the outer side is the better way. Since then you can beat the long nose problem at the same time and it becomes the correct side profile.
So I will pull out that insert and go this way. Maybe ending up with a mess, but that's a padawans risk
Staying curious about your progress! :thumbsup
I'm not worrying about the long nose, more taking Mac's lead and going on feel. Vader looks the way he does because of the sum total of all the detailed parts. The benefit of this to the average hobbyist is they can leave a few details out and still get a passable Vader. Partially because of the secrecy issues for finer details not being available and partially from what we're starting with, I chose to correct the most glaring issues and leave the rest alone.
I took out the nose piece because I had to, it was a bit messy after the work done, so I took it out and filled it in to correct width/depth. I had more issues with the bottom ridge on the bridge of the nose, just because of the odd angles to be sanding in. I'm very aware of what this helmet is lacking, but I'm doing it because I enjoy the process and learning about better ways to do it. I may well grab another rubies later to take another crack at it. I still have to paint, and I'm sure I'm going to screw something up, but I'm doing the best I can with the available knowledge about techniques on here. We'll see how accurate it gets afterwards.
Helmet has been primed over a couple times to fix minor flaws, so has the mask. I'm placing the magnets inside the mask mount and then doing a final prime before painting, hopefully starting this weekend as its been getting much warmer.
