CB2001
So, I figured out what was used for Doc Yewll's hand scanner featured in the show. It turns out to be a Thermacell Mosquito Repellant Model MR-GJ.
I've already got it torn down and already modified the "screen" so that it's open.
And I've got it sanded, ready to paint. But, I've encountered a couple of things. For one, from the episodes I was able to find any views of the device, I wasn't able to get a good view of the paint job (it looks like they got a silver coat for the base and then maybe lightly weathered it with some brass/bronze color and possible some light spray of black in the mix. Hard to tell because the only good pictures are all inside with one light source. The only thing I can tell is that they used a light grey color for the button, knob and screen).
Also, I would like to wire it up and I think they used an EL light ribbon/panel to light up the inside, but that provides a challenge (because as you see in the first picture at the start of this post, there is light coming from above and blow the "rim" of the screen (the screen is basically one solid piece of plastic and it's not possible to have an EL light ribbon/panel in place unless you cut the screen potion off at the top and bottom and then glue the "screen" in place on the ribbon/panel. However, as you can see in the other pictures, it looks like the they fed the ribbon/panel into the plastic piece. So, it leaves me with either the option of trying to match the first picture or to keep the screen a part of the large plastic piece. And trying to figure out if they used an EL ribbon/panel light or if they used something else is also a mind boggle, as the front screen has a light blue glow while the back side of it shows it a darker blue, which I haven't gotten a screen cap of, but is noticeable coming through that small "window" at the top of the device. In fact, I'd like to wire the "button" to have it turn on and off). I think I may have to replace the button also (as it's molded as a rounded piece while the one seen in the show is a solid flat. Not sure if they sanded, used fill putty and then sanded it flat or if they found something that had a flat end that could slide into the hole. Also, there's a hole in the lower back side where the butane cartridge can be seen (the butane heats up the metal flat piece that was originally there, and the repellant is a thing sheet material that goes between the plastic screen and the metal piece. The opening is for people to be able to see how much fuel the cartridge has). Due to the fact that the characters are seen holding it, they end up blocking that area so it's hard to know if the opening is still there or if it was filled in (which is another thing I'm considering).
I'm still scrolling through all the episodes to see if I can find better views of the device, but it is looking like it barely got much screen use. So, I know my final result may not be completely screen accurate, but it's a challenge nonetheless. If anyone has any ideas about how to do the paint and wiring, I could use any info. But, at least I'm at step B so far in this process.
