Mektar
I'd think E6000 or rubber cement would be best route, too. Just might need to let it cure a little before putting it on.
wouldnt it be better to put the pieces on while having the suit on tho?
Using E6000 should work because its some strong stuff. It works great for gluing the soles to the bottom of a lycra suit. Then again, standing with all your body weight on the sole helps. If anyone plans to glue the pieces onto the suit while wearing it, its best to wrap the areas of your body in plastic wrap as the glue will go through the fabric and then stick to you. Same thing if you glue it to a manikin. Only problem is you do have to let it set before you take off the suit. So I found it best to be prepared to do this when you have some time to stay in the suit while home. Otherwise if you take it off too soon, you'll have to start all over. My last MOS suit as seen in my avatar with my family, I used Beacon 3 in 1 Advanced Craft Glue (which is also the same as Beacon Fabri-Tac glue) for the \S/ shield. It actually helped to get the emblem to bend and conform to my chest. I used the E6000 for the soles of the shoes. Hope this info is helpful.
Okay guys I have included a video with full detail of the suit. Leslee the shoe measurements and sizing issues are on the video as well and I also PM you.
http://youtu.be/XqewBdBa0dE
2nd Video
http://youtu.be/yDnZ7saxKv8
Btw, dye sub undersuit or silver undersuit (w/o muscle shading)?
Who's undersuit is it? I was under the impression Bruce had only created mine?
Will give you a glue update this weekend hopefully
Masked Rider his his own muscle shaded shiny suit now. I think 6ring went with the full shiny undersuit..
Yeah. I went with the muscle shaded one, eagerly awaiting to see how it turns out. Anyone else go with that one?
I did; but I also added my own "special sauce" that I'll show when I get to posting pics of mine.
