My First Sonic. "Baker Based"
Paracord Junky
or "semi-custom" if you like. just a fancy way of saying it's not accurate.
about six inches without the emitter, solid steel, static, unless you count the emitter being removable. the activation ring WAS in the right place, but i screwed up on a final pass and had to move the grooved portion back.
the emitter was made entirely RPF Style using the ring from a cheap drafting compass, the magnet from a broken speaker, two washers, copper wire, and electrical tape(wrapped around the emitter stem to wedge it in place).
the key is found(i've got greeblies to glue on; just need to get some resin); the yoyo is a Duncan and WOULD be yellow if they still made a yellow Imperial, and the bag contains Sour Patch Kids gummies(or rather it did; i just finished off the last of them. mmmmm....)
