Having done this, I can tell you it's no easy task. While the front part of the canopy appears to just be glued down to the main body and relatively easy to dislodge, the rear part is actually trapped by the angle of the engine. The Engine blocks do not want to come free, so you will have to cut through the canopy. I thought that the engine blocks might be secured with screws, but they are firmly glued in place. Even popped the bottem panle off and tried approaching it from the underside. No go. Break out the X-acto.......
Gene
