zanderwitaz
I started this project a few months ago and it took a backseat for a while. I decided to make it the same length as my M-29 Incisor, and used this picture as a reference:
I was building this at the same time I was building my first mattock, so I didnt take many pictures as I focused on the mattock.
Anyways, here we go!
I started with the receiver details. I wanted to get these nice and crisp.
Then I did the little box details below that.
Little details on each side
Then I did the rest of the "flat peices" before laminating them together.
Scope riser. I've seen a couple builds where people skip this piece entirely!
Hollowed stock
Glued on shrouds, etc
Started on the barrels. At this scale, the PVC worked out perfectly
The barrel details are pinned for strength and are all friction fit for removal when painting
Barrel coming together
Blocking out the stock
Early test fitting
Stock roughed out and primed
foregrip and trigger area sanded down
The grip details. In retrospect, I should have drawn "penispenispenis" all over this volpin style.
I cant remember which end of the scope this is. Theyre both different though.
Annnnd the other end.
All the parts, sans the little "bolt" part above the stock
Primed up! (No easy feat with this much MDF)
My friend holding the gun as it sits now. Still need weathering, 3 details, and photoshoot! I'll be back.
Hollowed stock
Early test fitting
