I'm working on a sonic screwdriver, and I've figured out how I'm going to make everything, save for one detail.
Strike that, i've figure it out, but my intuition tells me there's a better way than what I've got planned.
Here's the part I'm talking about:
This is the head of the screwdriver. See the rectangular shapes that run up and down?? On the outside of the square, rounded-corners hole?? Those rectangles are part of the original stock. Not glued on. The diameter of the space in between the slats is less than the outer diameter measure at the slats.
It's sort of an exaggerated pommel from the luke ROTJ saber.
So the question is, how does one do that?? My first instinct was to lathe down to the OD of the slats, then put the stock on a mill and take it down to the appropriate diameter. But you'd have to do a ton of passes with the mill, rotating it a little bit each time. And then you'd have to go in and sand it smooth.
Seems like there's a better way to do it. For those of you that have done Luke ROTJ sabers, please chime in.
