LumberZach gets choppin away at a Mau5head
LumberZach
First and foremost I would like to thank Giz for helping me out. He answered any questions I asked him. I also used alot of his ideas and processes for construction, so If something looks familiar, that's who I got it from.
On with the pics.
Notes and measurements.
1/2" MDF lips I cut out with a router and circle jig.
4.5" acrylic hemispheres painted (on the inside)
Measurements and markings on the 14" acrylic globe.
Head hole is cut and sanded. Cut out using a Dremel with a fiberglass cutting disc.
Eye bracket template, the mold, and the two resin casts.
Mouth is cut out and edges are sanded.
Corners of the mouth were reinforced with styrene to prevent cracking.
Lips are epoxied in.
Another angle.
Just wanted to see how it would look.
Bondo'ed the top dimple and the lips...sanded smooth.
Primered.
That's where I'm at now. Hope to sand the head down today, and Bondo any remaining imperfections. Should have it colored by this weekend.
Hope you guys enjoy. More progess pics to come.
Alright, got some more things finished. Plan on flocking the main head this weekend.
Got the ears cut and coated. Awaiting primer.
Got the mouth section cutout, reinforce, and edges sanded. Need to buff it and cover it in fabric.
1 watt led's are epoxied to the eye brackets.
Temporarily attached the eyes to test the led's.
These suckers are bright.
Stay tuned, more to come.
Got some things done this weekend.
Got the mouth covered with athletic mesh.
Mock-up with eyes on and mouth piece in...looking decent.
Flock!
Closer look.
Now that I have to let the head cure, I have time to do a final sanding of the ears, install the studs, and get those flocked as well. The head should be complete by the end of this week.
Stay tuned for completion.
Okay, the flocking on the main head is cured. Now I just need to flock the ears and this bad boy will be finished.
Installed the eyes and mouth piece.
Another angle.
I plan of flocking the ears this weekend, so I should have pictures of this thing completed by mid next week.
Stay tuned...almost finished.
The head is done! Here are some more pics leading up to completion. Sorry I don't have a good completed shot, but should get some this weekend.
Where the frick are my ears?
Inside view.
Done.
Visibility is actually pretty good. I unveiled my head at a bonfire last Friday and wore it pretty much all night to get used to it and I had no problems seeing things.
The head looks great. How did you use the styrene? Was it a spray or was it something you had to lay down?
Thanks
Thanks
Thanks LazyT. The styrene I cut from a sheet. The styrene itself is 1/16" thick. That seems thin, but once you get it epoxied to the corners, it makes a world of difference. Make sure you have some good clamps to hold the styrene in while the epoxy dries.
Cool, thanks. I am going to attempt to fix my crack with that stuff unless I find something else during my search. What in the world did you use for the eyes? Yours having the perfect depth to them, almost looks like a rubber ball cut in half. I am hoping to find something during my search today (have to get material for the lip as well).
Holy crap dude. You may just want to start over on a new globe. That crack is going to be a ***** to repair.
I pm'ed you about the eyes.
yeah thats what i was afraid of. I MAY be able to salvage it. My buddy did some research on repairing plastic for the fairings on his bike and it seemed to be feasible. If it can fix those then I don't see why it can't fix this. We'll see!
that is an amazing mau5 head. What really impressed me is the flocking. I have always covered mine in fabric(its a real pita and no a fan of the seems). Could you possibly point me in the right direction to learn the process you used to flock that? Ive done a google search and only comes up with small scale stuff(like scrap booking)
That's a very nice mau5head. I like the wooden lips, I should have used that on mine... the flocking is very well done as well!
LumberZach your Mau5head looks wicked. What material did you cut the ears out of? Also do your eyes just snap onto those brackets you made?
I learned on the fly. I bought all my flocking materials from Don Jer. I also bought the air assisted flocking gun...made flocking the mask a breeze. Not to mention that I also bought a cheap $15 paint spray gun from Harbor Freight to apply the flocking adhesive.
Howd you get the measuresments for where all the eye,ear and mouth pieces go? Sorry im new
Allot of research and messing around in Photoshop. There are also a few threads on here that mention measurements.
Thanks!
Thanks Edgar! I used a 1" thick EPS foam sheet you can get from Home Depot. I had to coat it with gesso first before I sprayed primer on them. If you don't coat the foam first, any kind of spray paint/primer will eat at the foam.
The eye brackets are epoxied to the inside of the eyes. All the epoxy/glue I used on my head was either LocTite 5-minute epoxy or Gorilla Glue.
