Looking for an Arduino guru to help with a code project
ssdesigner
I've just begun learning the Arduino and have a basic understanding of how it works. What I'm looking for is a script that triggers 2 servo motors to turn 180 degrees, lights an LED (that stays on) and plays a 2 minute mp3 file. After the 2 minutes is up the led goes off and the servos turn the reverse 180 degrees.
Any help would be greatly appreciated. Send me a PM if you can help. Thanks!
After some thought I will probably have it setup a tiny bit different. I will have a mini momentary push button that needs to be pushed and stay pushed to do the following:
1) Turn both servos 90 degrees and stop
2) Light (and remain lit) the LED
3) play the 2 minute mp3 file
If the button is released at any time the mp3 stops, led light goes off and the servos reverse back the 90 degrees
Good news: You don't need a guru for this. It's too late today, but over the weekend I will prepare something for you. In the meantime you should have a quick look at the simple "blink" example - and then the "blink without delay", and make sure you understand the latter. That will help you to understand my code.
Could you specify two things:
- how is the system initialized at startup? Are the servos rotated to their initial positions?
- what happens if the button is still pushed when the 2 minutes expired?
PM coming! :)
