king kong map-FINISHED!
Stormer
hello everyone, most of you dont know me that well, but ive recently started drawing the hero map from king kong on the computer, helped out by Darth Sabers scans. Mostly becuase i really wanted a copy of this map, but also becuase i thought it would look a lot better if it was redrawn and hand weathered, as opposed to printed off with the yellow of the "background" printed in as well.
[attachmentid=12450]
Hi Stormer,
I actually started a Kong map last year (Using only the reference from the trailer) . After I got the high res scan of the real map I realized the sizing was wrong so abandoned the project in the hopes of starting it again later...Unfortunately I've been too busy.
Heres what I had so far -
(Here's my Thror map from LOTR, just for fun -
The first step is to study the map and find out what kind of materials you may need. If you look at the images of the scan you'll that the images weren't created with a traditional pen. You may need to go to a local art store and pick up a quil , calligraphy type pen or a brush to get the "thick/thin" strokes. Also, you may need to pick up some sepia type ink (Waterproof ink would be the best...Considering that you'll probably be weathering it with a liquid substance at a later time. Wouldn't want the ink to run in the wrong places).
Also, check out some yellowish or tan type of pulpy poster paper . Probably something in a heavy stock (not cardboard, or those poster boards used in school science projects). Once you've got the poster paper, cut it to size.
After you get your supplies, take the scan of the real map (front and back) and adjust it a bit in PS. Adjust the contrast.Lighten the light areas and darken the dark areas (writing and drawings). Once you've bumped up the contrast print out the image of the front and back. (The original map is 12" X 9.5" which probably means it wont fit on normal paper....Just print out what part you can, then print ouyt the section you couldn't print the first time and piece it together with tape...Like a puzzle.)
Now take the image (either front of the map or back of the map) and tape it to one side of your tan poster paper ( With the writing facing the poster paper). Now, lay the poster paper down with the taped image on the bottom. You should be able to see the writing through the yellow poster paper. If the yellow paper is too thick, then try putting a lightsource underneath.
Now, begin tracing the images very lightly with a pencil.
After your finished, remove the image that was taped on, flip the yellow poster paper over and reapeat the same process with the oposite side .
After you're finished, remove the taped image, and begin inking in the details using your brush or calligraophy pen.
In order to get the runny ink effect seen on the original map just take some of your ink, pour it into a seperate cup, and add some water (You'll have to experiment to get the right consistancy). Once you have youre right mixture, dip you brush into the ink and begin creating your runny effects (It's similar to using water colors). Test it out on a scrap paper first. If you screw up and it looks too dark just keep a paper towel handy and dab it...It should pick up most of the darkness of the ink.
If you want a runny effect with sharp edges (like the skull face image) just dip your brush into the watered down ink and lightly draw the image. If you want a runny effect with really blurry edges (like the word "FOG" in the upper right hand corner of the map) first smear some water on the map, then dip your brush into the watered down ink and draw on the wet area of the map...THis will create a "spreading" effect in the ink.
After you're done with the inking and runny effects, you can experiment with more weathering. Here are some more techniques,
- As I mentioned before, water down some of your sepia ink, but instead of using your brush, dip a paper towel into it. THen squeeze the paper towel over the map and let it drip. Let it sit for a few minutes then dab it with a paper towel. You can also use extra black coffee or water colors. Also, if you have an airbrush you can add some weahtering as well. For the creases, just fold the map, then take a piece of sand papaer and rub it on the crease until it starts fraying.
Hope that helps.
DS
i was hoping to just draw the whole thing in adobe illustrator and photoshop, and then just print it out with a laser printer, then weather it
i really dont have the kind of money to buy the supplies, as i just moved to indianapolis and havent found a job as of yet
but thanks for the imformation
well i finished up the front side of the map, done in photoshop and illustrator, and i think it looks pretty decent. it took a lot longer than i expected, but still only managed to take a few days, once i get my printer working im going to try and print some test copies so i can get the folds all worked out and done right, before i take it up to kinkos and have a laser copy made. Not sure if i'm going to do the back of the map or not, i guess that depends on if anyone here is interested in having a copy of it also
anyways, here are some pics, hope you like it
[attachmentid=12468]
[attachmentid=12469]
Wow...That's all I can say mate. Fantastic job. I want one.. So you gotta do the back now mate LOL
Admiration
TAZ
alright, ill get started on the backside of the map tomorrow morning, and should have it finished by the beginning of next week, then ill just have to see about getting it printed up, hopefully youll see an interest thread in the junkyard within a week or two.
well i finally finished the back side of the map, it looks great IMHO, but i might be a little biased ;)
heres a screencap of it
[attachmentid=12517]
Once I get my printer back from dell, I'll print off some test copies and see how it looks then, then get some professional laser prints. So far this has been shaping up greatly and I cant wait to get it printed, weathered, and hanging up next to the rest of my king kong stuff.
Depending on how good it turns out, I might do a run of these, so if you like it keep your eyes peeled in the next comming weeks for an interest thread in the junkyard.
That looks great.
I too have been working on the map, cleaning the images up and planning on hand-aging both sides seperately, then gluing the two sides together before adding the final "rough-up" touches, like the scratches and tears and deep creases.
So far here are how my clean-up attempts have gone:
Here's the front.....
and here's the back....
As soon as I've finished with my first attempt I'll post some pics of how it turned out.
<div class='quotetop'>QUOTE(Stormer @ Feb 8 2007, 06:15 PM) [snapback]1414643[/snapback]</div>
[/b]
Whoah, I must be having a brain-fart or something...just dawned on me what you're talking about doing....printing out the stains along with the map images, and only hand-tinting the yellowing and light smudges and discolorations, right? That's a great idea...much less work involved than the way I've been doing it, or at least less messy. :lol
yeah, it took quite a bit of time to do it on the computer, but im guessing far LESS time than it would take to accurately recreate them once its printed out, plus, if i mess up once its printed out, its not anywhere near as much of a loss....
Ok, I went ahead and hand-stained my map, since I already had it printed out...turned out alright, except that I accidently tripped a bit too unevently at the top, cutting off some of the text..luckily this was just my first attempt. Now that I know I can do it, my next one will be more accurate...I'll take much more time on it.
Besides, for the second one I want to add a touch of food coloring to give it more of an orange-ish color as it looks in the movie and not quite so brown as I've made it here.
Ok, I've tried it again...this time I adde a bit of yellow food coloring to the paper before aging with the walnut crystal ink...also added a few smudges of red in various places. Also, I tried to be more accurate with the darker smudging, though I think I did better on the first version in that area...but at least the coloring it better now.
Also, instead of two sheets done seperately and then glued together (which made it feel a bit too thick) I just did a double-sided map to begin with...it was scary sanding the creases to keep from grinding through completely, but overall I like this one better.
Wow, these finished products look great (Hats off to you guys.).
I just started on my map today. Im just going to do it the hard way (Actually drawing the whole thing by hand).
It may take longer doing it by hand, but I get to choose the style of paper I want, don't have to worry about finding a printer to print out the correct size (my printer only prints 8.5 X 11"...Piece of crap) , plus I enjoy recreating the details.
Once again , great job.
DS
Thanks to Ramsey. I did my own map and wanted to show you guys. Let me know what you guys think. I enjoyed doing this so much I'll probably be doing another better one.
Sorry about the bluriness
<div class='quotetop'>QUOTE(MaddChinaMan @ Mar 14 2007, 12:03 AM) [snapback]1439396[/snapback]</div>
[/b]
Very cool. You did a great job with that....it's a fun prop to make, isn't it? It can be a bit tedius, especially when you're hand-staining it, but it's alot of fun when it starts to look the way it's supposed to. Good work. :thumbsup :thumbsup
[/quote]
[/quote]
Thanks. It really wasnt that hard.It is actually on two pieces of printer paper. So it's not the exact dimentions. I'll be stopping by at kinkos to print a couple copies out and doing it agian but more close to the real prop(with exact Dimensions etc.). The shade of Brown/Yellow is a little off too so I'll be working on that. I'll kepp you guys updated.
