Iron Man Mark 5 FOAM WIP [updated Files!]- FINISHED Suit on pg 5!
Re: Iron Man Mark 5 FOAM WIP + Unfolded Files!
hi FatMan, the link you posted is probably dead. Would you please fix it? thank you so much!:D
Yes please! fix the link, omg i felt like i had an orgasm when i saw it.
hi, great work...i'm 6ft 6ins, what scale would i put it to?..and how do these files work? would i join them all together then cut out each piece in foam, putting them together like a jigsaw?...many thanks :)
Jjaysavaloi just get your height in mm and add about 50mm and you'll have your scale
1980-2000 mm height
cut out the pieces, then you have to do the jigsaw puzzle thing with the parts of the texture. It takes a lil while but it can be done. Always have your pepakura open amd some pictures of the actual suit to use as a reference.
Some more pictures. It's all one piece. Easy to put on and comfortable to wear.
Added buckles on the back. I need 1 more in between the 2 though.
Idk if sanding glue will work, I'd be afraid of tarring the foam.
i tend to use a heat gun (or hair dryer would work i guess if ya dont have heat gun) to warm up the glue just a little and then use some tweezers (or a different pointy thing) to then pluck out the glue, thats how i clean up some of my work
awesome, thank you...but i'm gonna seem really stupid...but what number amount should i enter for being 6ft 6ins? :) ..hope y'all can help :)
FatMan thanks for fixing the link!!
The Mark V is coming out really good!! I like the way you´re doing it in one piece, but have you allready make a move-test?
Hmm maybe I'll try that out.
I answered your question above, but I'll say it again. 1980-2000mm in height for you. :thumbsup
wow. . .this is incredible does the suit fit you well? great job
Yeah i can move around just fine. Fits great! The biceps are attached to the shoulders with a strap so they have mobility. Although I cant really bend in the abs region (like most suits), but I'm alright with that.:cool
hi fatman, many thanks..so i enter 2000 in the specify size on pepakura designer?...it just seems a little big when i enter 2000 lol :)
Where it says Height you put in 2000. The parts wont fit on the pages, you'll have to make them fit by splitting some pieces.
