Help: How to remove the endcap from a MR E-11
OdiWan72
Like the title says...I got my hands on a MR stromy blaster, that I´d like to take apart, clean-up, paint and put back together.
Problem is, taht I don´t have a clue how to get the damn endcap off :unsure
Anyone?
Markus
In an old thread someone reported second-hand that it's held on by silicone and can be twisted off, but that was absolutely NOT the case with mine. It's quite solidly welded on. I couldn't even get it loose using a propane torch.
So you have to go through the barrel shroud vents to remove the tab holding the stock onto the shroud, which is what I assume you're trying to do. Yes, the inner barrel's in the way, which means you have to remove the grip and remove the trigger group, revealing a couple of small philips-head screws. Remove those screws and the "bolt" will loosen, enabling you to let it and the barrel slide back into the tube. Beware that there are screws going into the tube from the inside of the mag well that will scratch up your bolt as it slides around if you're not careful.
By the way, I was unable to find a way to loosen the stock without permanently removing that tab, meaning that I had to come up with a new way to make the stock stay stuck to the shroud. I used a snap.
<div class='quotetop'>(Treadwell @ Oct 30 2006, 05:01 PM) [snapback]1347451[/snapback]</div>
In an old thread someone reported second-hand that it's held on by silicone and can be twisted off[/b]
I think this is the thread you mean: LINK
To remove the endcap:
Look at the picture below. This is Treadwell's modified MR E-11.
Drive out the tiny pin circled.
Underneath the fake endcap retaining mechanism is (2) screws. Unscrew these and then you can tap off the endcap. Actually you only need to remove the rearward as that is the one holding the endcap on.
The endcap has a snug fit so you can use a wooden dowel and hammer to tap it off. If you want to weather it, just use the hammer! :lol
Once the endcap is off, you can take out the fake bolt and barrel.
