all i can tell you is have a steady and consistant hand. use a grinding wheel and hold the knife at a 45 to 30 degree angle downward with the blade facing upward and grind slowly across the length, keeping the blade about 1 cm on both sides of the portion being grinded, perpendicular to the grinding wheel. move the blade in the motion to sharpen a few times across the grinding wheel before turning it on to get a good feel for it, and hold on tight! i suggest making a piece of curved stock metal to practice on.
