Hi guys,
Hopefully some of you electronics guys will be able to help out a COMPLETE idiot when it comes to electronics. I've decided to make a custom display stand for my MR Falcon because I find the massive mirrored base to be a bit overpowering.
On the current MR support rod, there is a jack plug which connects directly into the underside of the Falcon model. The power supply requirements for the lights is 9 Volts. I'd prefer to set something up which is battery operated (rather than play around with wiring that goes into a wall socket).
I just can't seem to figure out what is required to connect the jack plug to the 9V Battery box. I'd be grateful if someone could give me a "shopping list" of what I need to get to hook this up.
Here's the drawing. Thanks in advance.
Chris
Chris
