rollerboi
Heya, folks. I've always been interested in the egg chair, designed by Eero Aarnio.
We've all seen it in both of the Men In Black movies..
[attachmentid=10351]
We also see the egg chair make an appearance in the Prisoner series.
[attachmentid=10352]
The designer says, "I made the first prototype myself using an inside mould, which has been made using the same principle as a glider fuselage or wing. I covered the plywood body mould with wet paper and laminated the surface with fiberglass, rubbed down the outside, removed the mould from inside, had it upholstered and added the leg."
I'd like to make one for myself, with modifications. However, I'm concerned about the structural support aspect of the single-stem base and the chair itself. It appears as though the original designer constructed a mold around which the fiberglass was covered, and then took the mold out, leaving behind only a fiberglass shell. How, then, would you recommend constructing a smooth egg or ball-shaped plywood frame?
Will the fiberglass be strong enough to support the weight of someone sitting in it? I weigh about 210 myself. Are there any specific techniques that anyone could recommend for me to look into?
Also, I am concerned about the stem, or base of support. I've seen a number of people posed in the chairs, some sprawled out, others shifted to a side.. what should I be doing with the base in order to ensure stability? Is there a calculation, a formula that will tell me the minimum necessary thickness for the stem and the flange?
Thanks a bunch for any help, ideas, or comments that you could add to this project.
Links to tutorials would be more than welcomed, as well.
