HerculesFerrari
I recently came across the following blog post about an attitude indicator from an F-4 Phantom and pondered to myself how cool it would be to have an Apollo Flight Director Attitude Indicator (FDAI) to go with my replica DSKY. Having found no suitable models in any of my searches I went into research mode and set about doing it myself. Working from Block II reference photos, flight journals, manuals, and mil specs, I modeled it in Fusion. I'm uncertain if the originals were technically etched vs. engraved but the markings were very deep and sharp so I've been treating them as engravings. As such, all lines, tick marks, and numerals need to have the same uniform width and depth. Could they simply be debossed and get close? Sure, but I'm not looking for just close and debossing results in distortions on the numerals because it assumes linear projections onto the sphere. That meant I needed to create engraving line models for the numerals based on the Futura Medium font in order to get perfect alignment and a uniform engraved appearance. The trick there was to center each numeral over a sphere, creating a surface going back to the origin, trimming it to the sphere, and using that to create a 3-d sketch path along which to sweep a 1/64" sphere.
After sending the two half sphere models to my resin printer, and knowing I'd need to sand it smooth anyways, I filled the lines with acrylic paint markers and went to town. Trying to work with half spheres was clumsy at best so I modeled a little ring fixture to fit inside the shells and keep them aligned so I couldn't screw up by sanding and rounding over the equator.
At this point it has turned out so pretty that I which I didn't need to strip it and start spraying, but here we are.
Comparison with the FDAI on Apollo 15:
