NakedMoleRat
Legendary Member
Not a fan of the movie, but I love that prop! Makes me want to tackle it too. Of course, mine would suck next to yours! :lol
You obviously do not plan to weather it or chip up the inlays as seen on the screen used props, so while yours is not 100% screen accurate, it is still the nicest version of the prop I've seen.
And should you ever decide to weather it to match screen used prop, I imagine that could easily be done.
Good to see you over at Keep to the Code! There's actually a whole study over there on the dimensions of this compass. Many of us pulled together and smashed our heads against walls through brainstorming and trial and error on how to put these together. The search function is a huge PAIN but you can find it eventually.
Yepp - I have read that thread - it helped me to decide about the body size
now just some fine tuning and weathering :love
making of a brass scale.
First I made the scale with windows "paint" - saved as bmp with very high resolution. Inverted black to white and mirrored it.
Printing on a sheet of matt 130g/m paper from Tetenal with high contrast in the size I need for my compass.
Note that you can only use laser or Xerox printer - no inkjet possible.
get a brass plate and clean the surface with acetone (or girls nail enamel remover) - don`t touch it after cleaning !
put the printed scale onto the brass plate and press an iron on (highest temperature) for a couple of minutes. The toner is sticking on the plate.
Let it cool down and drop the plate into a bowl of cold water to remove the paper gently of the plate with your fingers until you can see shiny brass
use the kitchen sink and fill it with boiled water - put a glas vessel into the sink with Natriumperlsulfat until the chemestry has ca. 45-50°C.
tape the areas which you don`t wanna etch with Tesafilm or anything else
hold the plate into the vessel and blow in some air with a drinking straw - do NOT suck ! Check the result each minute til you are happy with it.
rinse the plate with cold water and remove the remaining toner with Aceton - et voila : a nice detailed homebrew compass scale :
