heres a vid Chris made for me, to help correct whats needed for it to fit right...just thought id post it to see how its coming along..it'll be fixed
https://www.youtube.com/watch?v=6wc7pPFmNFQ&feature=youtu.be
Please also keep in mind that due to the scope being mounted on the side of the Mauser that it sticks out a good bit - the blaster's main body should not be fully centered in the stand, rather slightly to the left, to help composite for the space that the scope mount and scope takes up. Like on here:
You can see that Master Replicas moved the whole thing to the left so that, with the addition of the scope, the ENTIRE blaster is centered, instead of the base gun being centered with the scope jutting out, throwing the whole thing off.
The final suggestion that I can offer is that it would help improve stability if you were to increase the thickness of the acrylic chalks that hold up the blaster, as the Elite Edition ones look to be about twice as thick as the ones that are on your prototype. Also, for the rear trigger guard spaced chalk, the Denix is quite narrow, much more so than the real deal, or even an MGC, so that chalk should also be approximated to roughly fit any of them.
And I get mount #1. :devil
He does have some valid points...except for the #1 stand comment of course.:rolleyes
