I've been slowly building up my own DC 15 carbine, and I'm finally getting to a point where I can start putting up a few pics.
I started off working with MDF and built up the layers as I went along. ABS barrel, sheet plastic to make a couple easy parts, and a little bondo here and there.
I've since shortened the folding stock a little more, and am still tweaking a couple of things. Then I got into the fun part.
While a wood and ABS scratch-built rifle is fun, I wanted to take it a step further and make something that could be a little more trooping-friendly. So I started molding things up and making one out of a high-density foam. It's lighter, and has a reasonable flexibility. I threw it against the ground just to see what the worst case could be. It bounced.
I've also been casting in a rigid pipe for support when it's hanging on pegs, etc. It could make for easy dis-assembly too, but there's still the stock to consider.
The barrel came out pretty clean (I handled it a touch too soon after molding creating a couple of low spots- lesson learned :lol ). First mold I've made, and it turned out quite well in my opinion. The receiver portion has a couple of spots that are trapping air, but that should be an easy fix.
I'm still working out the folding stock (not quite done the mold yet), and touching up some surfaces on the receiver portion mold to eliminate some of the surface irregularities. If that doesn't work out I'll just remold that part.
What's a little more rubber when I've already jumped in the deep end? :lol
The colour runs all the way through so any nicks and scratches won't be standing out like a sore thumb. I have yet to see how it takes Rub'n'Buff for weathering but that'll come soon enough. I gave a test sample a shot of spray paint. I found that while it coats well the paint tends to flake away from the foam underneath in areas of high flex. Not totally flaked off, but good to know all the same. Any suggestions?
More pics of molds, etc. and castings to follow as I get more done. Feel free to make comments
