Ok, now that these have started showing up on US online stores like whona.com, i figured we should get one thread to show everyones progress so far for converting these and "upgrading" them to be show accurate. The main things needing to be done are filling the vent holes, figuring out the back piece, should the battery compartment be moved to the empty right ear so the back can be cut off entirely for a replacement vacuformed one? Also, what type of paintjob can be done to this to get the cold cast look, would a combination of paint, weathering and rub n buff do it? Lets get this rolling, cause I know there are a few here working on this I just want to get it all into one thread, as the others seem to easily get lost around here.
Well to start with, we need to identify the type of inside lock clips used, the push button comes out the side of each ear, and in this picture, you can see how the back comes apart.
In addition, the back does just go inside the back lip, needs to go back whatever the measurement is from the end of the front piece to the middle of the ear where the push button is. I believe Hanger18 here was planning on doing vacuforms once he got a helmet, correct?
