Can I spray Liquitex Medium and Gloss?
Belfast Neil
As above, I have my mask finished and just needs sealing. Will this stuff work straight in to an airbrush or should brush it on?
Does it need diluted?Cheers.
ive used this in the past, on my preds BODY SUIT i thinned it alittle with plain water. I didnt want a thick coat as it does not flex as much as permawet and the suit moves more than a mask. Suit still has a nice sheen to it. ;)
Cheers Lee.
yeah as lee said just thin it with some water
i sprayed it on my skin about 6 months ago and it is still good
i use the stuff coz i still don;t have any perma wet, it works pretty good, as lee says it's not as flexible as permawet and what tends to happen if you over stretch it is that it wrinkles when it returns to it's natural shape.
i spray mine through an external badger cheapy airbrush with a little water, the less water you can put in the more shine you'll have and the more flex too, but then you'll clog your brush.
