I've been wanting a realistic Single Point scope for my Nostromo pistol and my Rebel Blaster. Since they are so hard to find,
I figured I could bastardize one of the round-cone ones.
So I got one off ebay and sure enough, the round endcap twisted right off. The greenish cap and stem would not budge.
Since I have no idea how to disassemble one of these, I took the sledgehammer approach and cut the end off:
Now, what I had intended to do was to take Shawn M.'s clear casting of the tip that was included with the Nostromo
pistol and mount it to the real scope. The only drawback is that the tip is solid and would look good from a distance,
but so-so up close.
So I got the idea to hack the one off of the Master Replicas one from the Rebel Blaster! Once I felt all the resistance
from the cutting wheel, my heart sank because I knew I was grinding through solid metal.
Even worse, when I was finished, the orange rode inside just flopped to the side. The extreme heat had melted it right
off the mounting post. The inside of the clear cap had also fogged up pretty bad. I thought ok, it is ruined and peeled
the cap away:
Amazingly, the cap had retained its shape and there was only some slight melting of the rod inside! I ground the cap
leftovers down until I had 1/4" of a lip left and it fit perfectly inside the real scope:
Now my question is how do I grind down the center piece in the real scope at (A) so that it is nice and flat?
Not a lot of room in there. I plan on just gluing the orange rod holder to it.
but so-so up close.
the cap away:
