MRBANANA101
Hey all - I'm attempting to brush melted monster clay into a large plaster mold so that I can do a bit of resculpting on the monster clay positive. I'm able to remove the monster clay positive from the plaster mold mostly successfully (by breaking the plaster mold), but it seems no matter what I do, the surface quality of the clay is always full of little gashes and tiny holes. Even though the clay brushes in very nicely into the plaster mold, the surface quality of the clay always suffers, and I'm assuming that maybe the hot clay against the plaster probably cools too quickly, causing subsequent brush strokes of hot clay not to overlap properly, resulting in gashes and poor quality? If that's the case, is there a method for keeping the plaster mold itself warm? Basically, the question is: Why is it that every time I brush hot melted monster clay into a plaster mold, the clay positive always turns out terrible, full of holes and pits? I've seen Brick In The Yard videos on youtube and they do a very similar process, except they brush the melted clay into a silicone mold instead of a plaster mold, and it turns out wonderfully. What is it about plaster that's causing the terrible surface quality of the clay? Or is there something else I'm missing?
Just a bit of background info. The original positive that the plaster mold is taken from is a very large (taller than 5 ft / 1.5 meters) 3D printed plastic (PLA) figure. It wouldn't work to modify the original plastic figure by hand, as the countless hours involved in sanding and attempting to sculpt PLA at that size can drive a man mad and certainly negates the hassle of making a plaster mold. Because of that, I decided to make a plaster mold and make a clay copy of the original PLA print that I can sculpt and add super fine detail to. I'm having no troubles making the plaster mold, or removing the final clay positive - just that the clay surface quality is terrible.
I've thought of alternative mold materials instead of plaster, like using alginate, but for such a large figure, considering alginate's working time, inability to bond with itself, and short time to cast into, it's been a bit of a disaster, even using alginate retarders. I could make a silicone mold for sure, but the cost of using silicone just to make a one-time use waste mold makes me shiver.
Thanks very much!
Thanks very much!
