drjag
EDIT: 10th Feb, 2014
I decided to upload the like to my album for any of those who want to view the images on a list. Sometimes, I also upload images but not post all of them on here so sometimes you'll see images that are not on this page.
Hellfire Build Photos by drjaguar | Photobucket
Greetings, good people of the RPF! I am yet again making a prop from Borderlands, this time, I'm making the Maliwan Hellfire! This gun, or at least the shape of it is one of the most recognisable weapons in the game, mainly because the base model is used, but the skin is changed, like for the good/bad touch you can get from Mad Moxxi, this is a good advantage because it means it can be painted differently.
I have been skulking around for other people making the Hellfire, The 2 that stood out was Jonny's Hellfire build: http://www.therpf.com/f9/borderlands-2-maliwan-hellfire-legendary-progress-176481/ and BRDencklau's Grace: http://www.therpf.com/f9/maliwan-smg-build-wip-196848/
BRDenklau's approach was the main inspiration, using dry floral foam to block out the shape and body filler for refined detail. This is how I will be approaching this but using layered extruded polystyrene. This stuff costs more but it's worth it.
So on to the build! Like I said, 3 layers of 1 inch thick extruded polystyrene were glued together using gorilla glue because not many other glues work. Next, I drew out a template from a blew up image of the hellfire. (the length of the gun is 55cm from tip to back for those who want scale.) Most of it is free hand and I changed the handle so your thumb can comfortably grip the handle.
Next was to cut out the outline, I did build a jig for a hot foam wire cutter but it simply didn't work, so I used snap off blades to cut it out. (snap off blades are also used for shaping the gun.)
Once the outline was cut out, I had to line what to carve out, if your going to attempt this, double check every line! Once you take away, its hard to add back.
More will follow soon, mainly carving, sanding and shaping. Stay tuned. :cool
