Has anyone IDed the gas/oxygen mask from Avatar? I'm certain it's not a found item, but does anyone have any such found item ideas that are in the ballpark? Otherwise it's going to require sculpting... that I'm bad at.
I thought that if you couldn't find an off the shelf item, perhaps you could vaccuform the frame and clear shield, with resin greeblies bolted on. Probably have to add a foam rubber gasket around the edge so the vacced frame doesn't chew into you too badly.
Any ideas?
Thanks!
Russ
Any ideas?
Thanks!
Russ
