I just got back from a few days away at work & attempted to mount my at-st on its mahogany base. I just discovered the white highlights i added with oil paint (after a coat of dull coat ) have eaten through the paint beneath & havent dried in 4 days. If you wipe the oil paint it comes off & shows the original base coat of black. NOOOOOOOOOOOO
The good news is it hasn't affected the surrounding paint & I have only used it on edges & some random light patches. What can I do, if i wipe it all off it will look a mess & if I dont touch it, it seems ok. Can I seal it or aid it in drying so it stays as is? Any advice would be a real help as I'm panicking a bit here & dont want to ruin my hard work with this stupid mistake. Is it not possible to apply oils over dull coat & what should I use to seal the acrylic paint before using oils & should I avoid oils all together? There is a pint in it for anyone that can help.....PLEASE:cry
