pandamajik
Member
Finished product looks good. Any tips on how you got the pieces to line up again after cutting it apart?
I'm working on a helmet that I had to cut in several pieces since it's fairly close fitting. The width of the dremel cutter I used makes it so there's a gap (don't think this can be avoided). I added some body filler around all the edges and did some sanding but I'm finding it difficult to get all the areas to match up really well. My current plan is to maybe put some vaseline/wax on one side and that way when I build up the body filler on the other piece I can just put them together for essentially a "perfect" fit. Not sure if my explanation is understandable but just trying to explain what my plan is at the moment.
