Another P1 Stunt Bio
Darth Pinhead
I am also the proud owner of one of the P1 Stunt Bios that George graciously casts. I have to say, since this is my first Bio project, I was quite intimidated to even touch the damn thing. I just sat and stared at it for a good week or so. At any rate, I've finally begun cleaning it up. My goal is not to necessarily get this guy smooth as glass. In fact, I plan on doing very little to the face of the Bio and intend upon keeping the major mold indentations. My major concern is cleaning up the edge of the bio and strengthening it with JB Weld Plastic Epoxy Putty. As I have read more than enough times, dropping these guys can lead to horrible results. Not that I intend upon dropping it (Who does?) but I do want to do my best to protect the edge from chipping. This is not to say the edge was not strong enough, just that I am super paranoid/anal and would rather error on the side of precaution. Applying the putty along the inside of the lip has also allowed me to build it up in places so that I can go back and sand it all down to a more consistant height all the way around the crown.
At any rate, I have spent four hours, over the course of three days, trimming the flashing, sanding anything major, and strengthing the edge of the bio with the putty. The putty I am using works GREAT. The JB Weld version (The Off-white) definitely does not stink as badly as the previous brand I used (Grey). I'm applying it by cutting off 1/4" slices from the stick, creating 1/4 ropes, and then smoothing it out with wet fingertips. Once I am content with the amount of putty that I have built up, I intend upon sanding down the outside edge, getting it as symmetrical as possible, and then will sand the inside down to eliminate some of the weight added by the putty. And yes, I realize I am spending WAY MORE TIME on the inside of the helmet than the outside (Probably more than most people spend on the outside, alone), :D
Laser Shroud & Air Tube References
Putty & Sanding Supplies
Masking, Primer, & PlasttiDip
Bio Upon Arrival: 12.17.2010
Post Initial Sanding & First Round of Putty: 12.27.2010 - 2 Hours
th_12272010-P1StuntBio1.jpg th_12272010-P1StuntBio2.jpg th_12272010-P1StuntBio4-1.jpg
Second Round of Putty: 12.29.2010 - 1 Hour
th_12292010-P1StuntBio1.jpg th_12292010-P1StuntBio2-1.jpg th_12292010-P1StuntBio4-1.jpg th_12292010-P1StuntBio5-1.jpg
Third Round of Putty: 12.29.2010 - 1 Hour
th_12292010-P1StuntBio7.jpg th_12292010-P1StuntBio8.jpg th_12292010-P1StuntBio9.jpg
Sanding of the Rim & Cutting Out Eyes: 12.31.2010 - 3 Hours
th_12312010-P1StuntBio1-1.jpg th_12312010-P1StuntBio2-1.jpg th_12312010-P1StuntBio3-1.jpg th_12312010-P1StuntBio4-1.jpg th_12312010-P1StuntBio6-1.jpg th_12312010-P1StuntBio7-1.jpg
Sanding of the Eyes & Detailing the Back Fin: 01.02.2011 - 4 Hours
th_20110102-P1StuntBio1.jpg th_20110102-P1StuntBio2.jpg th_20110102-P1StuntBio3.jpg th_20110102-P1StuntBio6.jpg th_20110102-P1StuntBio7.jpg th_20110102-P1StuntBio8.jpg th_20110102-P1StuntBio9.jpg
Sanding of the Shroud, Cutting hole in Bio for Laser access, Attaching of the Shroud: 01.04.2011 - 3 Hours
Casey (biohunter76) makes the kit with the shroud and hose connectors. He also sells the Pre-wired Tri Laser, however, I chose to use Jason's (PredatrHuntr) Super Bright Red LEDs.
th_20110103-P1StuntBio1.jpg th_20110104-P1StuntBio2.jpg th_20110104-P1StuntBio4.jpg th_20110104-P1StuntBio5.jpg th_20110106-P1StuntBio1.jpg th_20110106-P1StuntBio2.jpg th_20110106-P1StuntBio3.jpg th_20110106-P1StuntBio4.jpg th_20110106-P1StuntBio5.jpg
Applying First Round of Epoxy Putty to Shroud: 01.06.2011 - 0.5 Hours
th_20110106-P1StuntBio7.jpg th_20110106-P1StuntBio8.jpg th_20110106-P1StuntBio9.jpg
Sanding of the Shroud: 01.06.2011 - 4 Hours
th_20110107-P1StuntBio2.jpg th_20110107-P1StuntBio3.jpg th_20110107-P1StuntBio4.jpg th_20110107-P1StuntBio5.jpg th_20110107-P1StuntBio1.jpg th_20110107-P1SBComp.jpg th_20110107-P1SBComp2.jpg
Not So Final Sanding of the Shroud: 01.11.2011 - 1 Hours
th_20110111-P1StuntBio1.jpg th_20110111-P1StuntBio2.jpg th_20110111-P1StuntBio3.jpg th_20110111-P1StuntBio4.jpg
Another Round of Putty To The Shroud & Eyes: 1.13.2010 - 3 Hour
th_20110113-P1StuntBio1.jpg th_20110113-P1StuntBio2.jpg th_20110113-P1StuntBio3.jpg
Yet More Sanding of the Shroud: 01.14.2011 - 4 Hours
th_20110114-P1StuntBio1.jpg th_20110114-P1StuntBio2.jpg th_20110114-P1StuntBio3.jpg
Reshaped the Shroud, Prepped for Hose Connector on Chin, Finished the eyes: 01.15.2011 - 8 Hours
th_20110115-P1StuntBio1.jpg th_20110115-P1StuntBio2.jpg th_20110115-P1StuntBio3.jpg th_20110115-P1StuntBio4.jpg th_20110115-P1StuntBio5.jpg th_20110115-P1StuntBio6.jpg th_20110115-P1StuntBio7.jpg th_20110115-P1StuntBio8.jpg th_20110115-P1StuntBio9.jpg
FINAL sanding of the Shroud, Casey's Kit affixed, Primer Coats Applied: 01.16.2011 - 5 Hours
I used Rust-oleum Auto Sandable Primer Spray
th_20110116-P1StuntBio1.jpg th_20110116-P1StuntBio10.jpg th_20110116-P1StuntBio2.jpg th_20110116-P1StuntBio3.jpg th_20110116-P1StuntBio4.jpg th_20110116-P1StuntBio5.jpg th_20110116-P1StuntBio6.jpg th_20110116-P1StuntBio7.jpg th_20110116-P1StuntBio8.jpg th_20110116-P1StuntBio9.jpg
Masking Off & Application of PlastiDip Spray-4 coats: 01.18.2011 - 3 Hours
Peeling of PlastiShit, Etching of Shroud Line, and First Layer of Silver: 01.19.2011 - 2 Hours
th_20110119-P1StuntBio1.jpg th_20110119-P1StuntBio2.jpg th_20110119-P1StuntBio3.jpg
Rustification of the Bio with Acrylics: 01.19.2011 - 2 Hours
th_20110119-P1StuntBio4.jpg th_20110119-P1StuntBio5.jpg th_20110119-P1StuntBio6.jpg th_20110119-P1StuntBio7.jpg th_AcrylicRustPalette.jpg
Final Silver & Wet Sanding: 01.20.2011 - 1 Hour
I used a very fine thin sanding sponge to really knock down the metallic sheen and blend the silver in with the rust-job...
th_ChoppedSponge.jpg th_SilverSponges.jpg th_20110120-P1StuntBio1.jpg th_20110120-P1StuntBio2.jpg th_20110120-P1StuntBio3.jpg th_20110120-P1StuntBio4.jpg th_20110120-P1StuntBio5.jpg th_20110120-P1StuntBio6.jpg th_20110120-P1StuntBio7.jpg th_20110120-P1StuntBio8.jpg
Blast Marks: 01.22.2011 - 1 Hour
th_20110122-P1StuntBio1.jpg th_20110122-P1StuntBio2.jpg th_20110122-P1StuntBio3.jpg th_NoseTemplate.jpg th_BattleMarkTools.jpg th_BlastMarkProcess.jpg
Felting The Inside: 01.23.2011 - 3 Hours
th_FeltingSupplies.jpg th_20110122-P1StuntBio-Felting1.jpg th_20110122-P1StuntBio-Felting3.jpg th_20110122-P1StuntBio-Felting4.jpg th_20110122-P1StuntBio-Felting5.jpg th_20110122-P1StuntBio-Felting6.jpg th_20110122-P1StuntBio-Felting7.jpg th_20110122-P1StuntBio-Felting8.jpg th_20110122-P1StuntBio-Felting9.jpg
Cutting of the Lens & Repaint: 01.24.2011 - 1 Hour Lens, 2 Hours Repainting
th_20110124-P1StuntBio-LensCutting1.jpg th_20110124-P1StuntBio-LensCutting2.jpg th_20110124-P1StuntBio-LensCutting3.jpg th_20110124-P1StuntBio-LensCutting4.jpg th_20110124-P1StuntBio-Repaint1.jpg th_20110124-P1StuntBio-Repaint2.jpg th_20110124-P1StuntBio-Repaint3.jpg th_BlackWashSupplies.jpg
Lens Installation & Laser Plate Velcro: 01.26.2011 - 1 Hour Lens, 30 Minutes Laser Plate
th_LenseSupplies.jpg th_20110126-P1StuntBio-LensInstall1.jpg th_20110126-P1StuntBio-LensInstall2.jpg th_20110126-P1StuntBio-LensInstall3.jpg th_20110126-P1StuntBio-LensInstall4.jpg th_20110126-P1StuntBio-LensInstall5.jpg th_20110126-P1StuntBio-LensInstall6.jpg th_20110126-P1StuntBio-LensInstall7.jpg th_20110126-P1StuntBio-LensInstall8.jpg th_20110126-P1StuntBio-LensInstall9.jpg th_20110126-P1StuntBio-LaserPlate1-1.jpg th_20110126-P1StuntBio-LaserPlate2-1.jpg th_20110126-P1StuntBio-LaserPlate3.jpg th_20110126-P1StuntBio-LaserPlate4.jpg
Ha ..I just replied to your Facebook pics. I think the plumbers epoxy rim is a great idea ..in fact I have suggested it in the past. I used the stuff all over the battle torn bio ..in fact, because of its quick set up time, I even sculpt with it now and again ..many of the small peeled back shards on the aforementioned Bio were formed using this epoxy. Remember to use gloves when kneading this stuff together ..your hands end up a sticky mess if ya dont. Great stuff though ...hardens like steel.
Thanks for posting this Bro ..I love seeing the progress on these after they leave the shop
Glad you were the first to read this, George! Yeah, I'm a bit of a klutz from time to time and kept envisioning myself doing something stupid. I've even gone so far as considering epoxying carbon fiber into the inside (Not going to).
I rather enjoy using the JB Weld Plastic Putty versus the brand I used previously. Aside from the smell being much more tolerable, the previous brand stuck to my fingers, as you've stated, but this stuff comes right off. It also feels a tad softer and stays workable for 20-25 minutes, as opposed to three. The down side, of course, is that I go from a 1 hour cure to 3 hour cure. Ah, I guess we can't have it all, eh, lol. I'll be back on it in an hour with a third layer of putty and hope to be sanding tomorrow.
By the by, did you receive my PM on airbrushes?
Ha ..yes ..sorry for the delay ..PM returned
Nice work on the inside...mine is all sloppy but its only there to strengthen so looks don't matter. I know the obsession of cleaning up the inside and making it purty...I once covered the entire inside of a Celtic with felt. It was a bitch to do and I'd never do it again lol!
Looking forward to seeing you work on the shroud area :D
Shroud has been ordered, so it will hopefully be here in a few days. Until then, I have plenty of sanding to consume my time and I'm still trying to hunt down a local lense material supplier. I'm thinking I'll head to the auto parts store and have a look around. Oh, and kid yourself not, J, I will make the inside look pretty, :D
Whenever I'm gonna make it a wearable bio, I hit the underside with multiple coats of plasti-dip. Creates a great buffer on the latex mask. Do this before you paint the top side as to not ruin it with over spray.. I love plastidip.. But it's death in a can so wear a respirator and do it outside if you can
Thanks, Lem. It's easy to find time to work on your bio when your only consultant contract has put you "on hold", lol...
Brad, this is coming along so nicely!!!!! :) I can't wait to see it finished up! I am so jealous still of your P1 haha
Looking good so far your putting alot of work into getting right and it will pay off for sure, now can't wait to see it painted up.
