This is a build-up of a metal Siderio kit. I tried to get it as close to the Worldcon gun as possible, bar the wires, which is too accurate for me.
I left the barrel as unpainted, unpolished metal, with just weathering added. The cylinder cover under the lever was cut out with a small hack-saw.
The green leds are non-functional. I added the grommets to the side of the mag chamber and cut a small hole to add the switch, which was then filed out and filled with Milliput. I replaced the large screw at the front with a hex screw and added faux screws to the side of the magazine.
Thing weighs a ton
Thing weighs a ton
