Finally up! I'm taking orders for my 1/50 scale PlanEx ship model in several different configurations. Here's a look at what the finished result can be:
I'm offering these in "Flying" and "Landed" variants. Following the links to purchase will provide lots more photos of the kits in more detail. Here's the break down of what's included in each piece. .
Flying Version: $355.00
This kit is available to purchase here
This is a 19-piece kit; all parts are cast in urethane resin and will be provided untrimmed. Only the main hull is hollow, all other parts are solid castings. Finishing this kit will require sanding and light filler work before paint and assembly. The completed ship measures 24″ long, 8″ high and 9″ wide.
Included in this kit are the following:
Landed Version: $380.00
This 22-piece kit includes everything needed to make a freestanding Planet Express ship with extended landing gear. All parts are cast in urethane resin and will be provided untrimmed. Only the main hull is hollow, all other parts are solid castings. Finishing this kit will require sanding and light filler work before paint and assembly. The completed ship measures 24″ long, 10″ high and 9″ wide.
Accessories:
I also have pieces available to make the tiny wing tips illuminated ($10) as well as a cratered display base ($20) to show the landed ship. These are sold separately from the model kits so people can add options as desired.
For these items only I'm also including a discount for RPF members! Use the coupon code "PLANEXRPF" at check out to get 10% off the cost of any of the Planet Express ship model parts!
- Rotocast hollow main body “hull”
- 3 tail fins
- Turret with gun barrel
- Dark matter engine
- 3 “plugs” which fit into the landing gear recesses for a flat lower hull
- Bay door “plug”
- 8 window inserts
- 2 tail fin logos printed to vinyl decals
- 3 tail fins
- 2 rear landing struts
- 2 rear landing feet
- Front landing strut mount
- Front landing strut staircase
- Bay door “plug”
- 8 window inserts
Accessories:
