It could also simply be an error. I've come across spec sheets before with incorrect dimensions and inaccurately drawn diagrams (even CAD-drawn parts) that I knew were wrong. It happens.
Hi Gang,
My apologies for the sudden silence! Without getting into too much gory detail... I've been dealing with two VERY toxic "social" situations these past few weeks and one of them went nuclear on us. A lot of people were affected and upset. All is well now and the waters have calmed. Let's get back to work!
I finally got back to work on the nav chair buckles and Coughtrie Lamp Base
This a beautiful 3D print! Thanks, Iz!
Buckles
Lots of little gaps and holes to fill!
First round of Bondo filler
More bondo
Slowly getting there
Added some "Mr Putty" for the hard to reach areas
And more bondo
After looking at a few new images that dropped, I got to work and redesigned the more screen accurate greeblie that mounts to one of the extension panel lids
Slowly putting it all together
1/16th acrylic
Screen
Primer
The original greeblies were attached to the lid using pop rivets. I didn't want to take that route so I designed a more sturdy base
Basic layout
Interesting piece
This piece broke on me 3 times so I created a solid base
Primer
Laser cut this interesting piece
More Primer!
Love it!
Paint!
CaCa photo
Satin Granite Base
Mr Putty added to fill small holes and cracks
Silver!
I love all the little primer screw ups. Looks like divots in the metal paint
Close to finished!
Mounted - still need to add the side screen and add some weathering
And finally... Jake stopped in and has been wiring up different elements of the cockpit entrance!
SO COOL!
We tested a LED strip
They will light these red acrylic highlights! LOVE IT!
Adds so much life to the droid sockets!
And that's where we are! Lots more to follow. I DEF need to play catch up! :)
Stay Tuned!
Glad all is well. Hope it didn't include "inappropriate touching" and/or lawyers!
Love the lighting effects! The glow from the radar and the red strips are awesome!
This is what the RPF represents to me...
The way everyone comes together with their expertise, leg work, and experience to make another's project come out as accurate as possible...
There are other social media platforms, and other forums/communities, but none quite like the RPF.
Sorry to read about the car issues Sofa. Hope everything is working well enough for you now.
Sent from my LGLS775 using Tapatalk
Hey ST,
I couldn't agree more! This is one of the best sites for hobbyists. The wealth of information and willingness to help/guide others through their projects is endless. :)
Thanks for the words of encouragement. Things got toxic there for a while but the group banded together and worked through it. Life likes to throw you curve balls from time to time. Life is not all sunshine and rainbows... You got to take the punches and keep moving forward.
Great update Sofa...and good luck with the car thing.;)
Thanks, J! Car issues are all fixed. No more engine light! (knocks on wood)
Maybe he just doesn't have much to say or show yet
Hey OC,
ummmmmmm... ;)
Wait a minute... I think I heard the Falcon's toilet flush... I think he's still with us.
LOL! There was a LOT of fur to remove! We spent a week snaking the pipes! ;)
Glad to see you back. Sorry you had to work through some unpleasantness and hope everything's okay.
Hey SB,
Thanks! It felt good to be productive again. Still a bit emotionally exhausted from all the drama but we we're all bouncing back. Time to hunker down and get some real forward progress under our belts
Hey K,
OHHHH... that's what the doll is for! ;)
Thanks! I'm really excited to get the maintenance panel and cockpit entrance illuminated . Jake and I working to get that knocked out!
Looking great, as always, SK. Finally had a chance to get caught up (two months worth of weekend updates boggles the mind a bit, but WOW!)
Hi Gang,
Time for that "End of the Weekend Update"! Being Easter weekend, I took some time for me. Enjoy!
I bounced around a LOT trying to get to all of the "this and that" finished up. Getting this area prepped for LEDs
The LEDs will simply be adhered in place
More work on the Maint Console - I added the circular greeblie
Cut a hole for wiring
Jake is continuing his work on the wiring! COOL!
We're going to add a dimmer
Love the white bleed from the sockets
Note the light coming from the backside - I need to design a cover plate for the back
The new Extension Panel greeblie screen had to be resized
YUCK
I designed, laser cut and fabricated these new Extension Panel Lid corner greeblies
Silver
In place
I then weathered the panel greeblie
I went back and designed a new screen
Everything mounted
Work continues on the belt buckles
Finally... I worked on the door frame and managed to have a UGH moment
One side of the frame has to be reduced to allow for the Door Pads to wrap over top of the frame - I measured
Set up the guide
And cut
Time for the UGH moment... I got a call and became distracted. When I went back to the door frame I managed to cut the WRONG side! Naturally, I had to fix...:facepalm Added MDF filler strips
I then added the strip that I had JUST removed back in place. All better!
I did in fact get the correct side finished up
With the door frame now in place there was HUGE gap!
I designed and laser cut 1 of 2 cover panels - note the small access holes
1 1/4" piece of MDF and 1/8" piece of MDF
These two are adhered together
Counter sunk screws hold the MDF pieces in place
From the back
Counter sunk lid in place - in the event of a wiring issue we have small access panels to the interior areas of the cockpit entrance housing
Painted
Paint was still wet so I couldn't adhere in place
And this...
Is where we are!
Happy Easter to All Those Celebrating! :)
More to follow so stay tuned!
