Hi Gang,
Time for another one of those updates again!
Let's jump right to it!
First, I accidentally broke a piece... ugh
No worries...
While the paint dried I weathered the new assemblies
And dry fit into position
Interior side mounting plates
From above and in position
I masked off the 3rd and final headrest
Painted
Dry fit
Bolted in place
Looking through more images of the real ejection seat I noticed this little detail
Add some eyes
Primer
Paint
Time to mount and weather!
Love this photo! DEF needs more weathering
Laser cut these new guide plates for the nacelles
Paint
I laser cut new nacelle covers and dented these guys up a little to see how it looks - what do you all think?
Silver
Before weathering
After
Dented versions on the bottom. Yes? No?
I laser cut more nacelle guides
Primer
Paint
Inspired by fellow RPFer Fuzz, I decided to give a try at using rubber cement as a way to give the appearance of chipped paint. I painted the edges of the panel black
Broke out the rubber cement and dabbed it on as if items had hit the edges
Plop Plop Plop
Waited for the rubber cement to dry then sprayed with silver
When the silver dried I simply rubbed off the rubber cement! And Ta-Da!
YUCK! It looks like dripped paint!
However... A+ technique... F for execution!
Some areas look good. I need to be MUCH MORE careful with how the cement is applied
I'll sand smooth and start over
This angle gives a better idea how I want it to look
I cut these nacelle extenders
The original idea was to have the interior of the nacelle tips exposed but the covers I created took that away so I cut solid pieces and adhered into place
Work continues on the ejection tube cap / guide
Still lots of filler required
Told ya!
Its a never ending process
I really like this piece but I'm not sure if I can put it into it correct position
It attaches to the ejection tube and can be seen only from the back
There is a vertical plate
More on this guy later!
Finally... work continues on the pedestals
Added all the skins
Filler
PRIMER! That's a good sign!
I then had an idea... we DEF want to add more sound to the cockpit and these pedestals would make a GREAT bass housing! So I designed and laser cut these
What the heck is this?
Not only a pedestal detail but also a speaker grill!
2 More
Back side
Front
Primed!
Paint
Finishing up this one pedestal
Beauty rings
Paint
Grills temp in place... what do you guys/gals think? Yes? No?
I still have to cover the front / back sides
And this...
Is where we are!
Stay Tuned! More to follow!
