Hi Gang,
The past few days have been insane! 15-18 hour days for many of us. Unfortunately, the laser cutter isn't working and the CNC was down for a few days once again pushing our schedule back even further. Because of the craziness I didn't take as many photos as I would have liked. But... we've still been able to get a LOT done. Enjoy!
The old console wiring has been updated and repaired
I worked on the new canopy beams - turning this pile of confusion into....
This...
And this
And these
And finally these
As many of you know we picked up a wooden shift handle very similar to the original "El Toro" Shift Handles used on the yokes. Daniel is actually molding a new one. Once dried it will be sanded down to match the original size and shape then we'll make several molds
Before the laser cutter went belly up we designed and laser cut these LED housings for the vertical guages
Still need to be painted
I bounced around from task to task... working the main console greeblies
Eric was kind enough to mold these rockers for us!
New dial with black details
Knobs in place
After fixing the CNC Daniel jumped into action and cut these new window petals and main window frame
The petals required a little bit of trimming but they look awesome!
Adding/Sanding filler
I have only one photo of the cockpit entrance wall... the weekend has been insane! More on this later
A nice little surprise came in the mail!
A Huge thanks to Wavey for spotting this on Ebay!
It was time to finally paint and pin stripe the Volvo panels
Satin Clear
Panel #2 fought me the whole way!
But I won in the end!
Two new Volvo dash still need to be painted
And in place
WHOOPS... let's not forget this little guy!
Wiring, Wiring, Wiring! Enjoy!
Another panel down!
A Crowded House! These guys and gals worked their collective butts off! :)
Another panel done!
A few panels were messed up. A LONG TIME AGO yours truly accidentally put white LEDs into Yellow Fresnal Lens cover. Everything worked but the colors were off... So Eric and Brittany replaced the white LEDs with yellow! Almost ready to turn on!
Having fun with a fish eye lens ;)
Working well into the evening(s)
Closer and Closer!
Again, my apologies for not enough photos. It's been a zoo! Unfortunately, we've decided to stop progress on the canopy in order to not only address a few growing concerns but also focus our attention on the wiring and other vital areas.
I'm sure a lot of you have been asking why the mad rush... why are they working these late nights? You may or may not be aware but Episode VII is RIGHT AROUND THE CORNER!!!! We've been in talks with the Huntsville Space and Rocket Center to display the cockpit for the opening premiere! Our latest round of talks has the cockpit on display for at least 3 months! We're all VERY EXCITED but we're still in the discussion stages so we're not sure of the fine details just yet! That's why we're scrambling. We want to daze and amaze! And with only one weekend left... who knows what's going to happen! Fingers Crossed!
And this goes without saying, a HUGE THANK YOU to the entire team for another round of late nights, boxes of Oreo cookies, pizza, great company and excellent times! :)
More to Follow!
I honestly do not think I've ever seen a more devoted project than this one. It's just beautiful. I've showed all my friends and their jaws have just instantly dropped to the floor. Exceptional work.
Simply outstanding and unbelievable amount of dedicated and work going into this. Not enough superlatives to describe.
Chewie, set coordinates; 371 I can hear it now :D
"Oh My!! Do what must be done Lord Sofaking! Do or do not there is no try! I know!"
I'm excited as you are! i've been coming back at least 4 times to see that new update!
"It's starting to look a lot like chrsitmas , on all of these panels! "LOL
Hi Gang,
Another weekend come and gone. As you know it has been non-stop for the team and once again I didn't take as many pics as I would have liked as we were all engaged and focused. We all hope you are enjoying the progress and watching everything come together. Enjoy...
I reinforced the armrest levers with some brass screws
CJ continued work on the instrument panel LED display
Wiring continues!
The Volvo instrument panel getting a few layers of primer before paint
The new yokes were "vapor polished" with acetone. This make sanding and prep much easier! I'm hoping we'll be able to mount these before the show!
Yoke arms and base
Daniel and I worked on the door frame assembly and cockpit entrance / back wall. This was / is very complicated because there are so many factors to take into consideration: door clearance, door track, ease of assembly, wall assembly, transport, etc etc etc
The door frame assembly will be countersunk into the platform with a 3/4" base - another one of these many factors to think about
With door in place - temp
The Cockpit Entrance
The cockpit entrance wall will sit approx 18" off the back of the main body essentially housing the door frame. It will be 3 separate pieces (Left, Right and Top) that will bolt to the main body and to each other. We're hoping to then skin this great beast!
Cut in half
Temp in place - the wall will be flush with the door frame hiding the door assembly
Fish Eye Lens makes it a bit easier...
After lots of sanding and prep I was finally able to get some primer on the front window
Next few things are to figure out exactly how the window mounts to the frame, close in the exposed sides, prime, sand and then paint. Simple right?
Lights...
Another huge thanks to everybody and their continued help. You guys/gals are awesome! :)
Whew... More to Follow
Awesome update. Hopefully you'll have the yokes done. Would love to see how they look on the console. :D. Looks like you have the ILM team working non stop. As always the highlight of my morning. :)
Ok Greg... I have a solution for the whole "How to get it out of the garage" mess... see... here's what you do... you tear the wall out of the side exposed to the outside... then get a bunch of jacks and put them under the house foundation and lift the house and move it to left/right about 30-50 feet. Then you put the house back down and viola... it's out!
When you put it that way it doesn't sound difficult at all! ;)
Wow!
Wow!
Wow!
Two things: 1) I love it when you say, "sorry, not very many pictures this time," and then there's STILL a ton of pics. You're like Doc Brown apologizing for not painting/building his model of Hill Valley to scale! 2) I love seeing the shots of the whole team in action. You should give each other cool Rogue Squadron-inspired call signs. ;-)
A really unbelievable art project and a work of absolute unreal dedication. I honestly don't know how you are getting so many details right. What kind of reference pictures must you have? How do you know what some of the lesser seen sides even look like?
And then to get minute greeblies accurate -- how much would you say you are fabricating from scratch? Not found?
All I can say is thanks for the wonderful images. When you're done, you need to do an epic photo shoot. Wallpapers for everyone!
Hi BF,
Thanks so much! It really has become a labor of love at this point. We're all so excited to see how close we are to finishing this part of the build. And as exhausted as we all are the overall mood is nothing less than excitement and determination.
I scan the internet almost everyday for images of the cockpit and I screen grab what I can for different angles of the cockpit and other parts of the ship. Of course, a lot of this project is built upon Starkiller's original work and his dedication to build a screen accurate 3D model of the MF. For me, that's the pinnacle of perfection and I strive to meet and match that same dedication.
As far as the lesser seen areas, I just wing it. However, I use other images of similar greeblies for inspiration and direction. When you pour over countless images and screen grabs, you begin to get a sense of understanding how the original designer's put everything together and how they were weathered.
I would say 90-95% of the greeblies are hand fabricated. We've only found a handful of actual parts used but we're saving those for the actual build - if we ever get there!
Thanks again for the very kind words and I hope all that made sense. : )
Unusually quiet here, must all be working round the clock on the cockpit project!
lol... yeah... we've been working away!
He probably bent his laser bit again and ripped a hole in the fabric of time. If that's the case then I calculate he'll probably return in about 13.562 hours... but he might have a bit of time lag and need to take a shower before getting back online to post anything again. That new laser cutter has been causing these problems since he got it! LOL
No more talk about the laser cutter. Bad laser cutter!
Hello Mister King, I've been a silent fan of your work for a little more than 2 years if not 3 I don,t remember.. And I'm beyond excitement to see the extraordinary job you,ve done since de beginning. I've waited until today to create a profile just to tell you how much i love your work and dedication... I should,ve done it earlier but i think i wasn,t able then to create a profile! Oh well, I'm from Montréal Canada. Yes i'm a french canadian with a good english LOL i'm a costume desinger and set designer. and I love building stuff. I,ve been selling paints in a hardware store for almost 20 years so I follow your painting steps closely! LOL I'm a puppeteer as well . but just for friends. and i do a good Yoda and threepio voices. As you see on my profile pics i,ve made my own Jedi costume from scratch. So that's all for now can't wait for the next update! Bon Dimanche. Éric
Hi Eric,
Welcome to the RPF! Thank you so much for the very kind words. It means so much to all of us that we not only share the same enthusiasm but we're also able to share the project with everybody.
Sounds like you're having a great time with your own projects. I know we would all enjoy seeing some images of your work. :)
Hi C,
Thanks so much! I can't begin to tell you how honored I am to be working with such a wonderful group of people. They continue to daze and amaze! With that being said, we're aiming for speechless... But I think jaw dropping is just as good! ;)
Hi R,
Thank you! This last week will test everybody's dedication! I hope I have enough Pizza, Oreos, Little Debbie "Fill in the Blanks" and Mountain Dew to keep these guys going! ;)
LOL Thank you, Sir! It is starting to look like Christmas. I hope Santa leaves something nice for us under the tree. :)
Hey Iz,
Thank you, my friend! I'm really excited to see the yokes finished up and it place! It's really going to bring life to the console. These guys and gals are working hard! If they get tired I'll have to bring in the big guns... YooHoo!
Wow!
Wow!
Wow!
Hey M,
Thanks! If I had taken pics of the entire weekend there would have been... 300-400 photos easy. We were going non-stop! It was an amazing weekend. :)
I like the idea of call signs for ea member. Great idea!
Did you go forward or backward this time? :)
Yes. No... Wait. Yes.
Well if you went forward, did you catch the new Ep7 or did you forget again and it took you too long to realize it was the future until you got sucked back? Oh... here's your peanut brittle! :)
Yes with a "however" and No with an "except".
