Hello,
it's very warm weather here in germany, not the best environment for building models! But I got some more things done. The windows of the saucer are cast completely, I'm satisfied, although it's far from perfect. I wanted to complete the saucer parts by adding the smaller bits, but I discovered another minor inaccuracy I wanted to correct: The small dome on the aft end of the saucer should be surrounded by a recessed circular area which is not present on the kit part. So I widened the hole through which the clear part should be plugged to the diameter of the recessed circle and glued plastic card behind. Here's the result:
I've also ordered some LED strips in warm and cold white for the window lighting and drilled all holes for fiber optics in the saucer. I'll now glue the remaining parts together and add the fiber optics, so that the saucer is completed. A brass tube (14.29 mm dia) is ordered for the stand, and I have already a matching pug for electronics that will fit snuggly inside the tube. When this arrives I will wirk on the secondary hull.
Thorsten
Thorsten
