Re: Thorssoli's Episode VII Builds (Finished Phasma Helmet on Page 7)
...about the TIE and Snowtrooper... ...it looks like the lower part of the shoulder pad is longer than the TK/Captain Phasma version
Good catch. I'll definitely have to extend a pair of shoulders and remold them for the TIE Pilot and (if I ever get around to it) the snowtrooper.
It's been a while since my last update on these projects, so here goes...
Last week was a lot of molding, casting, and fume-filled fiberglass funk. Here's a shot of Ian and Anna glassing the last handful of molds:
Here's Anna taking a brief break before diving in and getting to work on the buttplate mold:
While they were doing that, I was prepping the gauntlets for molding:
And making mold boxes for some of the other pieces. Here's the box for the waist blocks:
Once we had a bunch of pieces ready for rubber molds, we started mixing and pouring. Here's the print coat on the gauntlets (in two different sizes):
Here you can see me finishing up the silicone pour for the waist boxes:
The gauntlets were designed to have a removable section on the inside of the forearm to make it easier for folks with bigger hands to get them on and off. Here's the mold boxes for the removable section:
And here I am pouring it:
In all, we burned through at least seven or eight gallons of silicone in a couple of days:
Meanwhile, fiberglass work continued. Here's Anna double-checking the black gelcoat coverage in the waist mold:
Here we are getting started on the fiberglass layup for a waist section:
This is Ian trying on the first pull from the larger-sized chestplate:
Later, he was appraising the first pull from the new buttplate mold:
Fiberglass molding was still happening much later in the week than I'd have liked. One of the last pieces to be molded was the larger-sized vest/back piece. Here I am prying the mold halves apart:
The back side popped off easily enough, but the front side proved a bit more difficult:
Once it was removed, the prototype was destroyed and the molds were polished up. Here's a group of us in the middle of that process:
At this point we almost had a full set of parts for the Phasma suit:
We were missing the right thigh (one of the last fiberglass pieces to be molded) and the forearms. So it was time to get back to work on the gauntlet molds. Anna and I spent some time thickening them up:
The dog (her name is "Leeloo") played a vital supervisory role.
After a while, we'd made all of the fiberglass parts we needed and the molds were getting in the way:
Once they were broken down, most of them fit neatly into a large moving box:
With time running short, we curtained off an area of the workshop and set Ian up with the cutting wheel so he could trim all of the fiberglass parts:
Meanwhile, the rest of us were hard at work. Here's Cary laying up fiberglass mothermolds for the gauntlets:
Here's Matt talking his wife through the process of priming a trimmed helmet:
A little while later we had Matt try on a set of fiberglass parts (so we could dress him as a TIE Pilot):
On the TIE Pilot front, things were running behind. Matt managed to finish all of the chest boxes and I'd done the final sanding and gloss coat. Then they went under rubber. That night must have been the coldest night in the history of my workshop though because even a full 36 hours later, the silicone was still sticky. Hoping for the best, we forged ahead with progress on the helmet. Since we didn't have enough time to wait for the 3D printer to crank out the visor attachment for the top of the helmet, Matt went ahead and shaped one by hand:
Here's Ian trying on the helmet prototype with some of the fiberglass parts:
The prototype needed a bit more polish, but here it is with it's first gloss coat:
Once the glossy lime green had dried, Anna set it up for molding:
Then it was time for the print coat:
For a moment she had quite a lot of help:
But mostly she was on her own:
In the end, we ran out of time and we weren't able to have any of the four suits we were working on ready in time for the premiere. That's the bad news.
The good news is that a new friend of mine in Southern California used one of my Phasma helmets and the Phasma-specific add-on parts (codpiece, hands, and ankle plates) and modified her Anovos Stormtrooper suit so she could wear it to the premier. Here's a good photo of her:
and another one:
This one has been getting around a bit more online though:
Here she is with the original:
And finally, a full-length shot:
I think she did a pretty good job.
