MonsieurTox
Gladly!
I'm hot for infos on this too, but unlikely that I will start to build before end of this summer or even a litle later.
I don't have alot of pix of the underside and actually no top views of the bridge, so for the moment it seems to me that one Möbelwagen is enough.
The side skirt idea is good! Maybe a Stug IV or so...I'll have a look for this.
Btw: I've took some measurements (very roughly) and I got 41cm for the with of the bridge.
A lot of surface that needs to be detailed...
Well I built the basic structure (head and neck) and mine is also 41 cm ! That's a good news
I dont have a lot of pics of the underside too Actually I only have Franck Wire's (excellent) pics as ref. No pic of the top, except the one in the SaG book !
As for the underside what I have so far :
portside : most of the area is covered by the Shinano deck (argh 2 kits to find !). There is also a 1/72 Airfix Matilda parts (side skirt, like the Tamiya ones used on the facia).
Starboardside : Junyo deck (close to the neck). Junyo deck is also used four times on the neck on both sides (you need 2 kits for the neck and bridge).
Actually I'm pretty sure that's a side skirt because you can see the panels and the square bolted thing which links the panels !
If you need any help for the basic shape/angles, let me know, I'm not saying my measurements are 100 perfect but I think they are close and they match the kitparts placement !
