KrangPrime
These where my first joymonkey sets from astromech. they where fun to setup and install, as soldering is real hands on stuff with instant results.
it was also fun to learn how to solder right. these guys are still in my r2 working properly after years.
eventually, I wanted something a bit brighter. I upgraded to the LED edition. and bright they where. only problem is, they where ten times tougher to setup and install.
I eventually ran out of fiber wire because I made so many mistakes trying to get the little wires run down to the right sections. when you think they where in the right spot, and noticed they wheren't, you had to re run it, but the length of the wire was wrong...and then... ugh...it got so frustrating, especially after breaking one of the support boards. that I eventually gave up. i'm probably going to wind up throwing them out. I only got the rear logic board assembled, and the stability of the fiber optic cables isn't very good....they easily fall out if it's not exactly the right length. for those of us not expertly skilled, the previous set was far easier.
so, here is a question. also open to joymonkey if he's on here, since I don't visit the other site that much anymore.
would it be possible to have the basic led board done and printed up so you DON'T need to run the wires? just plug and play? I realize the LEDs would have to be super small, almost as small in order for it to map out correctly, but if so, it would be OH so much nicer an install. just plug and play.
just curious if such a thing is possible to design. even if it'd cost more..and if anyone would be wiling to do a run. my front projector is starting to get a bit dull..you can hardly see the red LEDs anymore, so it might be time for an upgrade ;o)
