Hi Gang,
Some updates. It's been a brutal couple of days with the temps in the high 90s with 70-80% humidity making it feel 106-112! But...
Weathered this little
Mounted this greeblie - still need to add the rockers (which need to be cast) and a few other little details
Believe it or not... this is actually the beginning of the new canopy! When I originally created the upper nose panels I didn't realize the top of the panel had a 15 degree pitch towards the center of the cockpit. So I'm adding that now...
Strip the panels.. again
Remove the window channels
Plane and sand smooth
I then ripped a 2X6 at the 15 degree angle. This was a killer to do because I had to make 6 different cuts so the blade could handle the thickness of the wood
What appears to be a window channel is actually two separate pieces joined together. For this cockpit - there will not be any windows
Cut the ends off, sand smooth and ensure everything fits
Here you can really see the 15 deg angle
That channel is VERY deceptive
Load it up with filler
Back to the oven to continue on Han's side...
