NakedMoleRat
As the title says....So I wanted to re-do my sonic screwdriver remote control conversion that I did last year. My intent was to just add solid claws to my build. But in true geek fashion....
Before I go any further, a BIG THANKS to Dan (Anakin Starkiller) for his help! You, Sir are a gentleman and without you I literally would not be here.
I remembered Dan's post on his sonic build http://www.therpf.com/f9/11th-sonic-progress-update-1st-post-130064/In
In post number # 16 he mentioned that he had to have several claws made....so I PM'ed him asking if I could buy a set from him for my sonic.
He sent me some, along with a couple accurate emitter tips.
So getting going on that, well....it wasn't long before I realized that the claws were not going to work easily with the remote. The silver slider on the remote is a little too long which makes the solid aluminum claws too short to use with it. The 'neck' where the emitter sits is too thick and not tapered like the prop is supposed to be either.
But I want to use the solid claws. So my thought is to modify the silver section to work. (It can be done, but will take a lot) Now my mind is telling me....fix the copper collar.....fix the copper collar.....
But to do that, I also need to redo the copper slider......so back to the PM's with Dan. And as a testimate to his nature of helping fellow proppers out.....he draws me 3D files for Shapeways (Since I cannot machine items, having no lathe or skills to machine them like he does) and I order a set of copper parts.
I am in the process of sanding off the print lines, etc. This is a WIP pic.
So, when I have them all finished, I will get them copper plated.Want to see how they look next to the remote grip and handle? Glad you asked.....
The earlier mentioned claws....WIP
And here is an emitter painted with several washes of transparent green, a lite dry brush of white, then more washes of green. I tried to give it the marble look.....it sort of worked. With a bulb behind it, it looks pretty good.
And claws and emitter together...
And lastly....a group shot.
More to come.....
More to come.....
