Totally agree Quake , in an ideal world it would be great . If no one does a licensed costume then I will definately do a run . No names but at least one maker of comic parts got a cease and desist order Over here though.
I still need to perfect the materials though yet. I used a rubber backed with PU foam on the eagle and when stitched on it was a little soft and the thread pulled on the rubber and distorted the edge slightly . I've got some new supplies on order at the moment so I'll see what works best .
It does need a degree of flexibility and softness as the top and bottom will knock together when the arm is raised as the bottom eagle is strapped to the arm as well.
Also to be aware of is these are scaled to Urbans so are meant for someone 5'10 to 6ft and over . Anyone shorter and they will come to far down the arm.
I am considering as Anderson sized set though too
:cool
