Zabana´s Iron Man WIP - BOOTS FINISHED - Page 13 (NEW LEG PAGE 14)
Re: Zabana´s Iron Man WIP (NEW Helmet V4 page 12!!!) Gloves finished
Im about to paint my armor and my favorite part is the hands I got from you. They are amazing
lm about to paint my armor and my favorite parts are the hands I got from you. They are amazing!!!
I´ll love to see your work dude!!!
Have you got any WIP pic?
And thanks ^^
Aaaagh! I want the hands sooooo bad but i just dnt have the $$$!
Hey Zabana,
First of all .. thanks for your hard work on the files, it really pays off and I love your model!!! I wanted the most accurate .. and you're it!!
I've built both your hand and foot (1 of each for now) and they look amazing! I have extra large hands, long fingers etc .. so I went at +10% of your stock scale, that makes it 100% for the hand and 100 index .. the rest of the fingers are to come but it'll be the same.
The foot was also scaled by 10% and I've got size 12 shoes. If I find a show that is tight all around the foot .. it'll be perfect!!! It leaves a little space all around for some padding if you don't want to use a shoe in there! The shoe in it's current pic state is fiberglassed inside with Smooth-On EpoxAmite! Very solid model!!!
Here's some pics
Comparison:
2 pieces/slip over show - Dancing fool
3 pieces high heel (bigger model) - ROBO
2 pieces accurate - Zabana
With size 12 foot
High rez and more pics here
Nice pics. It is good to see them compared to each other. I combined Zabanna's model with Robo3687's method and made a new pep file. Check my signature and follow the link for the Mk VII pep files if you want to check it out. I also added a light pod for the boot thruster that fits in Zabanna's boot. It was based on this scene:
Awesome work on these files. Keep it up.
Hey Darkside .. yeah .. I also have downloaded your files! :)
You've done a really good job merging both concepts unfortunately, I'm already at 6'3" so I don't need the extra height under the shoes! ;)
I also took a ton of screen cap and compared them all to Zabana's files and they're really accurate to the movie!!! I strongly recommand them to all IM pepers!
Dude I´m amazed!!! :O
I´ll follow your wip for sure ^^
Keep building!!!!!!
Hey Zabana,
Here's some pics
Comparison:
With size 12 foot
Thanks bud!
I actually don't have any WIP for once .. even though in the end, I figured it would be helpful if I would make it less a show off but more a "how I made it fit for a tall guy" kind of thread.
I'm almost done pepping the other hand now .. woot! I'll post more pics when I'm done! Oh and btw, yeah, your files are quite a mess to pep .. but it's much much easier the second time around!!! :)
I had a question i hope that you can help me with... What type of hinge joint to you use for the Thigh to Shin connection???? i have been pondering this for a while now and i have yet to see anyone really share their secrets.....
One,
I plan to use screw rivets (I'm sure there's another name for it). One part will be stuck in the calf extension, while the other river piece will be fixed in the bolt joint. So that I can put them on, then screw them together easily.
Alluminium Screw Rivets - Splinting Tools, Splinting Accessories, Wire Benders, Bandage Scissors, Heat Pans, Finger Rivets, Heat Guns and Heat Pan Liners from Handy Healthcare
Your looking for chicago screws, they have them at HomeDepot etc. I don't think they will be strong enough or spread enough area for strength to work well in the knee area. Foe my build it will be a moded version of this type of hinge with a slide inpivot so it can hook in just like the hero suit. :)
Clinton,
I`ve never seen that type of hinge before .. do you have a name for this?!
I did not complete the leg yet so I didn´t worked on it´s hinge yet as well, but I was thinking in a kind of hinge like Clinton says.
More pics of the Zabana hands for the unconvinced! :)
SCALING:
By default, Zabana's files are at 0.9 for the hand and 1 for the fingers. Since I have extra large hands, I scaled the hand at 1 and the fingers at 1.1. Now, the fitting is not as perfect as I'd like, the hand might have been perfect at .96 but I won't redo that for now.
As for the fingers, the length is good but they're big around .. I might have to remove a strip before glassing them. A good solution for peeps with long fingers would be to print them at default scale and then add a strip in the middle after cutting them from the paper. I figured this would be like scaling but only on 1 axis ..
OR I could ask someone to modify the 3D model for long finger hands .. hint hint! :D Zabana, you got a PM!
And here's how I joined the parts together for those who'd be wondering ... Oh and btw, buying and receiving my Silhouette cutter just before doing those hands really saved me about 50 hours of cutting! :)
Wow Man!! Your peping skills are better than mine for sure :love (also ï´ll love to have a cutter machine too hehehehe)
And PM answered ;)
P.S. Thanks for the pics.
SCALING:
@Bigturc
Indeed those are very good peps. I had minor 'glitches' here and there on my hand files that I was able to fix in the finishing stages. What did you use to glue these parts together?
Thanks Mike,
I always use white glue, cheap 150ml bottle at the dollar store!!
I just can't understand people using hot glue to pep! ;)
Oh and it does help now that I received my Silhouette cutter! Although it's not always cutting exactly on the printed lines for me and for small parts like this, I cut my own folds!
