Vacuum Pump requirements
Wrenchman
Hi guys,
I've been here as a guest for some time but I've finally decided to register and say hello and get some advice.
I've been vacuum forming for a few months now, using a vacuum forming table and shop vac. - mainly small rc models ect. but I'm looking to upgrade the vacuum because I want to try my hand at prop making and I want to get the pulls as sharp as possible on some detailed large moulds for scifi wearable armour pieces.
I've contacted some local pump shops and they've recommended some pumps ranging from around $400 up to $2500.
I was hoping to get some advice because I know many of you have been doing this for years and have used a range of tables/vacs.
Do you think a vacuum pump with the following specs would get a nicely detailed pull on my table with the forming area dimensions approx 18"x18" and the max mould height 8":
Two stage 12 CFM rotary vane vaccum pump Pumping speed: 12 CFM
Ultimate vacuum: 3 Pa
Rotating speed: 3500 Rpm
Power: 1 HP
Thanks for your help, guys.
Wrenchman
