Re: Tutorial: How to build a stormtrooper helmet for less than 10 GBP Update Sunday p
Hi everyone! I'm sorry I haven't been on much the last couple of days. I've been busy doing a little plumbing job for someone. They wanted me to spur off of a radiator and fit an extra one in their new kitchen extension. It was while I was at the DIY store buying the flexible hose and fittings that I made a discovery. When you plumb, using flexible hose you need to insert tube supports into each end of the pipe to stop the compression joint from crushing the pipe and causing a leak....Well the tube supports in question are pictured below....remind you of anything? :eek
This little buggers are going to become my Mic Tips!
Anyway, I have redone the ears a THIRD time, as I still wasn't happy with them, and have spent even MORE time sanding and filling and sanding and filling and............well, you get the idea.......
So, here are some pics of the work I have done over the last two days. It doesn't look too different from Sundays, pics, but, believe me, I've done a lot of work to it! Tomorrow, hopefully, I'll put it in Primer and THAT is a goal I have been working towards for what seems like an eternity.
I hope that the ears are looking ok to everyone else???
Well that's it for today....Tomorrow I will finish the sanding and get a base coat on it. See you then!
